1 - 19 of 19 Posts
This happened at roughly 2-3 psi while driving through an intersection in traffic. Not sure what caused it. Luckily all the pieces were found in the pre turbo pipes. Nothing after. New DR-650s installed + oil lines and running strong - good compression. Will post more on the build later. Have any of you seen this before?
Rear turbo (stock 9b):
Rear pre turbo intake pipe:
Front turbo (stock 9b):
3SNY - HondaTurtleFTW
Looks like some thing got sucked into the intake and went to the rear turbo. Or a flaw in the machining of the compressor wheel.
Sent from my MB865 using AutoGuide.Com Free App
Discussion Starter #5
oh wow! are all bolts and nuts accounted for?
Coop
Yeap! No missing hardware. I thoroughly cleaned my intake and intercooler piping prior to installing the DRs.
Discussion Starter #6
Did you get these from Dynamic racing?
Oops, forgot to mention these are just the stock 9bs. Edited my post to include this info sorry. :eek:
Super Moderator
I thought it looked like a 9b lol... but you said DR650 installed, so I got confused.
How many miles on them? And was this out of nowhere, or had you done some work on the car prior?
Escaped
If you need a set of 9b's I am selling a set.
Discussion Starter #10
They were 10k miles over due for a rebuild so I wouldn't say it was out of no where. Surprised it happened at such low boost though. Currently it's my daily driver so I baby it way too much. I only open it up on free way ramps after the clutch is fully engaged and even then my max EBC setting is 12psi. I only use the freeway a few times a month.
I installed DR650's last weekend. :)
Discussion Starter #12
10k past a rebuild? Curious where you got that info as I have seen many stock turbos go for 150k+, surly you dont have that many miles.
Coop
Shaft play at 120k inspection.
General & A/V Moderator
Well that explains things lol! How are you liking your billets? Notice a difference?
Discussion Starter #14
Unfortunately I Haven't been able to take it out yet - I wasn't careful enough with the radiator install and the A/C bolt mangled it. The engine runs well but I can't put it under load until I get the new one, which I just picked up today from Performance Radiator for $150 (oem spec). I'll let you know though! I took quite a few pics I'll share soon. :)
A/C bolt (Image courtesy of 3SX):
Discussion Starter #16
Is your MAS webbing still there?
Yeap and in perfect shape. That was one of my first thoughts but no missing or damaged honeycomb whatsoever!
Twin Turbo
Did you replace your intercoolers? Could be debris in them. I wouldn't have though the wheel would shatter like that just with shaft play.
Sent from my GT-I9000 using AutoGuide App
Discussion Starter #18
I cleaned them. No particles were found within the intercoolers / intercooler piping though. That made me feel a bit better.
1 - 19 of 19 Posts
