It wouldn't really help the turbos spool, because they don't spool based on exhaust flow alone. You need to have engine load before the flow will be enough to build pressure. (you also need some heat transfer, but that's a little different.) Theoretically you could use a supercharged and twin turbo set up, however, you would probably be pushing too much boost into the engine. Also, I've seen a few first generation MR2's using a "twincharged" engine setup using a single turbo into a supercharger, however, I wouldn't try it with our engines. The only quad turbo charged engine I've ever even heard of is the Veyron which is a quad turbo W-16 (or is it W-12?) that pushes in excess of 1000hp (at the flywheel anyway). Personally, I wouldn't even think of adding a third or fourth turbo to our cars, as our engine is too small to even need that much more flow. If you get a set of turbos that will match the engines displacement, you really don't need the extra turbo(s) anyway. Heck, the IHI ball bearings will hold 25psi to redline (on the stock engine, thats around 530hp anyway).
(I know that some of the above information is missing small things/possibly incorrect, however, this is a basic explanation)
Also, the supra twin turbo (93-97) did not have a sequential turbo setup. The RX-7, however, did. Either way you look at it though, twin turbo cars are designed to decrease spool time using two smaller turbos to achieve the same amount of boost as a larger single turbo, just with less boost lag. The RX-7's sequential turbo system doesn't cause one to spool early, the other to spool later, with both pushing at the same time, it actually uses one for low end boost, and the other is used for high end boost while the first (and smaller) shuts down. In essence, it's a single turbo system that uses two different turbos, one for low end, the other for high end. Quite an intelligent system though. I could explain how it works (or atleast the most simplistic and probable way it would work) but I won't annoy everyone with my babbling.
