1 - 4 of 4 Posts
Cams: Where less is more
what is the purpose of a torque converter? can someone give me a good detailed description of what its for? ect thanks:D
Senior Member
Your torque converter is a fluid clutch designed to cause slippage in the transmission at low RPM. This way you don't stall when you come to a stop the engine can still turn but the tranny output stays stationary.most Torque converters are designed to operate at an rpm around 600, Some race torque converters operate up to 3500 Rpm.
Discussion Starter #4
"Modern torque converters can multiply the torque of the engine by two to three times"
whoa:eek::eek::D:D
i was a lil skeptical when neo(i think) posted the dyno sheet of the ss with almost 700 pds of torque and JUST:rolleyes:300 hp :eek: :D
1 - 4 of 4 Posts
