1 - 3 of 3 Posts
Is posible change or remove the Power Steering Pump Pulley V style for add the 92+, or I need replace the power pump pulley complete and this fit on the 91 engine ? I got the crank S 92+ and the PS tensioner 92+ all ready for the conversion.
SDSU Alumnus
  • Like
Reactions: GreSnake
Disregarding your reasoning for the conversion, it will be much easier and simpler to just swap the PS pump as well.
Helpful info:
Converting from 91 V-Belt to serpentine <<
Thank you for your answer, is fit on the 91 engine? Yes that was part of my question if is more simple replece all, but the reason is: the crank shaft pulley 91 is hard to found .. And more expensive, you can found the 92+ and deal price and diferent materials
1 - 3 of 3 Posts
