Initial testing with this pump showed I had a healthy voltage drop in my electrical system which made this pump perform slightly worse than its smaller Devil's Own counterpart. The pump is physically larger than the standard size pump and draws a few more amps. If you run a progressive controller from another alky vendor you may want to contact them about this pumps amp draw before you purchase it. The Devil's Own draws 10amps and the ProMeth PM190 draws 16.5amps. I also have a Snow Performance pump that draws 11amps. The ProMeth pump will draw 150% of what the other pumps on the market are going to draw. That's why initial testing showed the ProMeth pump was under performing vs the Devil's Own pump.
