1 - 6 of 6 Posts
Open it up!
I have the annoying problem of the coolant light coming on frequently. I fill it up, then it comes back on. Had the car to the dealer 800 miles ago and they warmed it up, did a pressure test, and could find nothing.
There's no sign of leaking coolant on my garage floor.
The dealer says there's no sign of coolant in the engine - he said it would be very visible by turning white. is this true? even with mobile1?
So 800 miles later, the coolant light is back on again and I drive it that way to dealer. He pressure tests it again for 20 minutes and can't find a leak again. WTF??
I have about 1 month left on my factory warranty and need to get this fixed. Anyone have any ideas?
Jeff
Possibly the water pump weaping under your timimg belt covers. Hard to get to to look at, but may be the problem.
Steve
Hate to tell you, but its sounds like your water pump....
when the car is not running, it doesnt leak.... could be why the compression test passed....
I had the exact same problem, no sign of leaking etc, I kept filling it up and up and finally it got to the point where if you run the car have a quick spin around the block, then stop and look under your car, might see it leaking... but definetely sounds like the water pump, I had no sign of leakage for a while...
All I kept seeing is that damn roman cathedral type icon light thing hehe
chunsangp
That's exact same thing happened to me like 2 months ago.
I couldn't find any leak under the car so I took it to the dealer
and let them have pressure test. They couldn't find any problems.
OK, later, I found out i had bad radiator cap.
Try to retighten your rad cap or replace the cap and the gasket. Your issue could be very minor just like me.
Good luck!
1 - 6 of 6 Posts
