the Precat's eliminators from DN are very expensive, the back one must be crazy to make, you can have a local shop make you a front Mandel bent Pre-Cat eleminator for under 75$ and you are better off gutting your Rear Pre cat, unless of course they run emission test in your area, then you should make sure your have a spare one just in case... (I bought a used one of the list for not too much)
