1 - 5 of 5 Posts
My 92 dodge stealth power windows dont work unless the door is open and even then it has to be open at a certain angle(like open a couple inches) but doesn’t work at other angles. Any help please thank you.
Senior **i.e. OLD** Member
Broken wires (from fatigue) inside the loom from the door to the car.
Mostly likes right where you can see the loom in between the door and the car (or within an inch or of there).
Very common issue.
Sometimes tricky to fix because of the location.
Do you have a manual?
If so, you can at least pinpoint which wire (by color) may be the (or multiple) wire(s) compromised.
If not:
Good Luck,
Bob.
CAD/DAO/CNC
Exactly Bob...that happen to me first years i got my car ...in 2004.
Discussion Starter · #4 ·
UPDATE**
I unplugged the connection and plugged it back in and my windows work now🙏🏽
3SNY - HondaTurtleFTW
The harness between the door and car has broken wires. Take the fender off, wheel well liner off, and run new/repair wiring.
Sent from my HD1907 using Tapatalk
1 - 5 of 5 Posts
