1 - 1 of 1 Posts
My passenger power window doesn't work from either switch (drivers side window works fine). There is no noise created upon actuation. My thought is obviously that it is the switch or motor. Also passenger power door lock doesn't work - from either passenger or driver switch. Driver side lock works fine. I was thinking of replacing the passenger D/Lock actuator and the passenger lock-window switch. While I have the door apart should I look to replace anything else?
(I am hoping that the window motor is fine and am thinking that it might be an expensive part to buy- I of course would test it when I had the door apart.)Is the trim panel hard to remove-any ideas of parts prices for above items or known problematic parts? MANY THANKS FOR ANY ADVICE
1 - 1 of 1 Posts
