1 - 11 of 11 Posts
G
Ok. The time has come to get new rotors on my VR-4. I'm getting way tired of the stock rotors warping so easily. I think I've settled on Power Stop cross-drilled rotors. Anyone know a good/reputable dealer? How much should I expect to spend? I'm probably going to order through Porterfield, but I'd like some input. (I'm getting new pads too, probably the R4-S pads) Thanks guys... I appreciate any assistance!
Jon -- '92 VR-4
The cheaper rotors you buy the faster you gonna replace them. DO NOT by cheap crossdrilled ones ... and NO Power Stop ones. Or do you just like the look or do you relly want to brake !
G
Discussion Starter · #6 ·
what is the total difference of the brake systems on the VR4 vs. the SL? I have a NA car and wondering if all I need is the bigger calipers and rotors to make the swap. I would like to do this is mechanically possible and financially worth it.
G
Discussion Starter · #10 ·
I assume with your screen name you must be from St Louis. There is a small shop in University City called Lightspeed Motorsports. They sell and install the Powerstops. I have Powerstops on my Stealth and have had no problems. They haven't warped like my stock ones. Hope this helps.
1 - 11 of 11 Posts
