1 - 3 of 3 Posts
This really sux. I think I may have blown a head gasket. How ???? I have no clue. I was wondering if anyone could help me out.
Here's what happened today:
Driving around locally for an hour or so (running erands) and I come to a red light. After a few seconds , my coolant warning light goes on. ( I figure ok I'm probably low on coolant) Next , for the first time ever I see my oil pressure warning light flashing on and off. Next thing I know there's thick white smoke coming out from under my hood and beneath the car. Once the light turned green , I immediately pulled over and shut the car off. After popping the hood I noticed the smoke eminating from the overflow coolant container. My coolant is literally Boiling and Bubbling and is HOT as a Mother Fu*#er. I also noticed brown and black sediment deposits inside the container. This is what leads me to believe I had blown a gasket. What bugs me though , is the fact that my coolant was full and all the hoses I could see were all attached and intact. My last oil change was 1000 miles ago. I haven't even been beating on the car either. So right now I'm very pissed (obviously) and confused as to how this could have happened. Any advice would be greatly appreciated :cool: :confused:
Ferrari Nut
Diagnosis:
Have the brown sediment checked for anthx!:eek:
A compression check on all of your cylinders will verify a blown gasket. I donno what that boiling water/coolant situation is all about, but could be a thermastat or water pump issue.
When coolant is being burned in the cylinders, usually puff white smoke comes out your pipes.
Is your oil whiteish and milky? If so that could also be a blown headgasket. Kinda strange though...we don't usually have headgasket problems. Even those of us running alot of power.
1 - 3 of 3 Posts
