1 - 3 of 3 Posts
vr4stealthrt
i POSTED THIS B4 BUT NO ONE RESPONDED TO MY POST. My car used to shoot out white smoke and run like crap.. and the third cylinder had compression only of 91psi and the rest were all fine. So i took out the head took it to a machine shop and got all new valves and seals.. and head gasket .. and all done up nicely... Now we put it back together but it still has low compression.. Now we did a leak down test.. and when we put oil in the compression rizes... so can this b the piston or rings.??? please people respond back i really need help and will appreciate you guys thanks..`
~marco
Yup.
If you've eliminated the head and the head gasket as the problem, then that just leaves worng rings, broken rings, missing rings, cylinder larger than spec, or a big hole burned into the piston.
1 - 3 of 3 Posts
