1 - 10 of 10 Posts
A VR4 mechanic at a mit.dealer thinks I need a new turbo. When I start my car in the morning it runs like shit, (bogs,chokes,and backfires) but after it warms up (5 - 10 miles) it runs better, not perfect but good? Could this be a turbo problem, it seems to me like a bad air/fuel mix or sensor. Any help would be appreciated,
thanks,
Eric
V
Guest
Does your exhaust blowing out a lot of smoke?If so,it may be
caused by your turbos.If not,probably it's your air/fuel mix.
I would also check the termostat.
Also,when is the last time you have your car tuned up?
perpetual college student
I agree, no smoke = no turbo failure
I would check your plugs, wires, and perhaps the ECU capacitor ($5) swap from John M. in the for sale section
More Than Meets the Eye
Not <i>this</i> John M btw :)
You need to check your plugs and wires and all IC pipe connections. I'm pursuing a theory with the fuel pressure regulator solenoid on the firewall but it'll be a while before I have any definite results.
How old is your o2 sensor? At part throttle the car relies on it for your mixture. If it's almost dead, you could be running way rich.
I agree..
Check your sensors BEFORE "Mr. I want to make this stealership as much $$$ as possible- mechanic" yanks your turbos and your wallet!!
Possible probs could be:
1. O2 sensors
2. Mass Air Flow
3. Coolant Temp sensor
4. I/C lines
5. Vaccum lines (cracked, loose)
Check these prior to your turbo swap
D
No, it doesn't sound like a turbo. But you may have a couple of problems. The bad/cold - ok/hot, sounds like the coolant temp sensor gone bad. It's fairly cheap, and easy to replace. I'd start there.
That Others May Live
You will know if the turbos are going bad if you have oil in your intercooler pipes. Pull off your pipes at the Y-pipe and if you have a pool of oil, then its your turbos. But from the sounds of it, that wont be necessary.
1 - 10 of 10 Posts
