Yes, I did it myself. It is relatively easy. You need to take off the downpipe (the bolt on the rear precat is the biggest pain in the ass). After that there are 5 ~ 17mm bolts that connect the transfer case to the tranny. Basically you slide the driveshaft on first and then bolt up the 5 bolts. It took me a total of an hour and a half to put it together. About 20 minutes of that was getting that 1 downpipe bolt on. I also have an air compressor and air tools which made it a bit easier. Hope this helps you out.
If you happen to live in the Austin area and want to use the air compressor and tools just let me know.
Phil ~ '92 VR4 (ON THE ROAD AGAIN)
[Edited by redvr4 on 10-11-2000 at 03:18 PM]
