Parts Inventory for STL3S
1277 Views 9 Replies 8 Participants Last post by  bfarnam
Note to MODS, please don't move this post to classifieds because it's not a public for-sale thread, thanks.
Note to STL3S guys, this list will be edited as parts are used and added, but check US3S for up-to-date listing. Sorry for the lack of organization. If your interested in something on this list, PM me here or US3S, don't post here. If your not STL3S, keep an eye out in the classifieds as most of this will be posted there with prices every now and then, or PM me.
If other STL3S guys want their spares added to a list PM me, next post reserved for your parts.
Drivetrain parts, stock:
1. driveshafts/axles. Front and rear
2. TT front knuckles with uncut ABS sensor, one possibly bad wheel bearing
3. ECS struts and stock springs, all 4 corners, not leaking
4. ECS strut caps, working, 5-6 total F+R
5. Rear AWD subframe, Complete except for diff and axles
6. Wheels, 4 1G stealth TT with tires, 8 16" DSMs (4 aluminum, 4 steel with tires), 4 17" 3G DSMs.
7. power steering pump, 92+ belt type
8. AWD power steering pump res.
9. A pile of stock lug nuts
10. ABS sensor rings, front TT
11. gutted main cat
12. ungutted front precat
13. *Placeholder for 6-speed rear diff in near future*
14. AWS rear pump
15. AWS rear rack
16. Booster hoses with check valves, both clutch and brake
Drivetrain aftermarket:
1. SS clutch line, new
2. SS brake lines, new
3. Modded throttle cable for cruise delete, short method
4. 4 Fittipaldi 17" wheels, with tires
5. 3SX rear TT control arms, new
Body stock:
1. Popup headlights, pearl white covers
2. Pearl white 1G hood
3. front fender support brackets
4. SRS sensors
5. ABS unit
6. brake master cylinder
7. clutch master cylinder
8. clutch booster/pedal assy x2
9. brake booster assy
10. rear view mirror, great cond.
11. 1G light buckets, ready to install
12. rear hatch + glass, pearl white, AA wing hole pattern
13. Pearl white rear taillight caps
14. fuel tank, no broken studs
15. fuel pump sender unit, pumpless, with hotwire relay attached
16. front subframe pieces
17. steering rack, TT
18. 1G dash, upper
19. airbags, 3 drivers, 2 passengers
20. SRS computer x3
21. ABS computer x2
22. Pearl white passenger door
23. side windows
24. e-brake assy
25. 1G shifter assy
26. pearl white passenger door mirror, power
27. front wiper motor and bracket
28. 5-speed shifter cables
29. rear tow hooks
30. *placeholder for removable roof glass section*
31. removable roof sunshade, tan
32. Stealth black Lexan headlights, reconditioned
Body "aftermarket":
1. Robo modded glass Stealth headlights, black insides with red rings, lenses swapped for HID use, or can be swapped back if wanted.
Other:
1. 2G stock radio, tape player with aux port, for CD changer
2. 6-disk CD changer with 2 cassettes
3. CD changer cables
4. aftermarket cd player, will post model # later
5. Smokin VR4 single DIN radio plate with 52mm hole and blitz turbo timer cutout
6. Blitz dual turbo timer
7. GReddy mechanical boost gauge, 1.5 bar, white face
8. stock amp, premium sound, TT cars
9. Dome light assy
10. tan hardtop headliner
11. dash tweeters, not blown, x6
See less See more
1 - 10 of 10 Posts
Those ABS sensor rings be mine!!!!
I have another pair.
I am in Marion, IL, about 2 hours from St Louis and have a partout going of a green 92 VR4: http://www.3si.org/forum/f4/parting-out-green-92-vr4-90k-482653/
I sell my stuff cheap, especially large parts that I can't ship. I have had a lot of people drive 2-3 hours to come get parts. I am open to trading for any upgraded parts to fit my 92 Stealth TT. Thanks.
how much for robo mod headlights and pics please. pm or [email protected]
Ok . . . so I am replacing my plug wires and had to clean the K&N . . . and uh oh my stock BOV has a nasty rattle . . . spring is probably broken which explains a LOT. So does any one have a stock or DSM BOV in the STL area that they dont need and are willing to sell?
Call me ASAP if so 3147133356 - Brett
I have a stock BOV somewhere that you can have if I can find it. I know I have a couple aftermarket ones.
Thanks... HighBoosted brought over an EVO valve last night . . . it is working for now . . .
1 - 10 of 10 Posts
