1 - 10 of 10 Posts
Whenever I accelerate hard, or even fairly hard, my parking break light comes on. I assume the sensor just needs to be tightened or something. How would I go about fixing this?
.jon
Check your brake fluid.
Its the light that comes on when I put up the parking break. It never comes on unless I take off really fast. It makes sense, because that would just slightly move the brake up. Its just enough to set off the light. As soon as I get off the loud pedal, the light goes away.
Does anyone know where the sensor is at?
.jon
Add some brake fluid! I'm serious.
If I recall, the reservoir is located in the upper right hand corner under the hood (when you're facing the car).
Top it up and you're on your way! I've had the same problem.
Mike
Discussion Starter #6
Heh, i just got it. It all makes sense now. I'll check the fluid next time i'm out there. Funny thing is, got an oil change a couple days ago, and i heard the guy say i didn't need any brake fluid. oh well. thanks
.jon
My car has been doing the parking brake
thingy for a while now. Now it just stays on
almost all the time.
I'll try adding brake fliud this weekend, if
it works this board fuckin rules.
i bet its not the fluid level. These cars were rated very low for problems with electrical applications by consumer reports.
Notice how you can wiggle the ebrake up and down a little, b4 it engages? It may not be adjusted properly, or the little tiny itsy bitsy switch located in the console opposite the handle is misadjusted.
If you ask me specifically where it is, i will tell you to go buy a manual. ;)
Discussion Starter #9
already have a manual - just too lazy to look it up. guess i'll have to get off my ass :)
.jon
One Shizz-rippin' M F
The light doesn't go on when the E - brake is adjusted wrong, the e-brake just doesnt work. Its most likely the brake fluid level, it goes down on its own slightly when the brakes wear, and it doesnt need to be that low to trip the sensor
1 - 10 of 10 Posts
