1 - 2 of 2 Posts
Since both of you guys have the MSD dis4..tellme how to hook it up also the tach adapters.....thanks!...JC
Installation is very easy. Just look at the manual and you will see a typical 6 cyl layout that could have been copied out of our manual !
- You only use 3 of the four channels and use 1 1/2 of the coil adapters.
- You only have to tap into 3 wires and use of ground and 12V
- I got the connectors/plugs that go into the stock coil pack from a salvage yard as this made installation even more easy.
- Settings can be made to your gusto, nothing special there (retard is not needed)
- The box can be placed under the front fuse box if the stock airbox is removed. The coils also use some place and for sure I will relocate them sometimes ;)
Please note that the ignition alone did not result in any better behaviour (only a week and then problems came back). Only in combination with a good coil-setup (like the Accel one) this probably represent the best ignition solution currently available.
1 - 2 of 2 Posts
