ok so yesterday i installed the egr blockoff plates and now am only boosting to 7psi. did i do something wrong? all i did was remove the egr valve, blockoff the vacuum lines, and blocked off the egr tube. after the install i put the tube back on and reconnected the vacuum lines and still the same thing. so i am gonna put the egr valve back on and see if that fixes the problem. it could just be that i blew a turbo at the same time of the install. any info would help.
thanks
thanks
