1 - 9 of 9 Posts
Large Member
Well.. I came across an outstanding deal on turbos... but they need rebuilding. How possible would it be for me to rebuild them myself? Keep in mind I'm very mechanically inclined (timing belt and water pump replacement myself, tranny swap mostly by myself, etc.. and all without a manual).. Where would I start? what would I have to buy?
On the other hand.. how much does it cost for a pro to do it?
Large Member
Discussion Starter #2
oh, and by the way.. they aren't stock :) I'm not sure yet what size they are...
really not too bad... seriously
I think texas turbochargers and turbochargers.com have replacement cartridges for sale...
pop it apart, replace, port the crap outta it... done.
Dare to be Stupid
I think the rebuild kit is around $150. Can't remember if that's each or both, and I think it comes with a video.
IDIC
Okay guys.. don't laugh
HAHAHAHAHAHAHA
oh..sorry :)
if the rebuild doesn't work out, or they're just too trashed to rebuild, drop me a line..i want a busted turbo to play with. Good luck though :)
-Aaron
'94 R/T TT
'95 VR-4 Spyder
'95 Pearl Yellow R/T (belongs to Mom)
Large Member
Discussion Starter #6
ttt
Got Boost?
Ahahhahahahahahhahahahahahahahahha. Just the thought of that makes me laugh. Ahahahahhahahahahahhahaha.
"And now you, in the privacy of your own home, can rebuild turbos with the Sally Struthers Turbo Rebuild Kit©."
Life begins @ 30psi
Depends on what's wrong with the turbo's. Sure anyone can put new seals and bearings in them. But do you know if the shaft is bent? Housings have cracks in them? Both of which you cant find out or fix if discovered. Then they need to be VSRV balanced when they're done. It's up to you though.
Large Member
Discussion Starter #9
ok.. some more info. They are stock turbos, that have had the outlets ported and a larger compressor wheel installed with fins that have a different pitch. The person I might get them from got them from Ed Arnold Racing. They said that they make some noise, that it might be the bearings or the shafts that might need replacing, but they haven't been "looked" at by anyone to see what the matter is..
1 - 9 of 9 Posts
