1 - 6 of 6 Posts
So car was running great. Great oil pressure just couldn’t be more perfect. All of a sudden running rough but when I gassed her in neutral the break pedal would be come so stiff. In fact when it started running rough the break pedal was stiff. But when I gave her gas in neutral the gas pedal wouldn’t push down at all..
for the brake issue check the vacuum at the brake booster to see if there is any.
the rough running is a whole other issue
start with checking for boost leaks
It was running super good for a change then it started acting up and the brake was hard to push. Every time we fix something, something else breaks haha. 191k what can you expect. I have a 92 sitting in the garage with 112k and a bad engine
lol you probably have more issues than just boost leaks with that age and mileage car you will have to locate the search button for the boost leak test GL
Are you sure this is correct? The throttle is cable driven so if you can't press the pedal something is physically blocking it.
The break booster is vacuum assisted, if the hose going to it has come off or torn the pedal will become very still and you will have a large vacuum leak which could cause the engine to run poorly.
There are a number of ways to check for boost/vac leaks. Because I haven't bought the proper tool I stick a garbage bag between the filter box and intake pipe in front of the MAF to seal it. Then I dial down the regulator on the shop compressor and hook up to one of the vacuum lines, usually the clutch booster reservoir hose, pressurized the system and listen for leaks.
There might be a better way but that works for me.
1 - 6 of 6 Posts
