21 - 28 of 28 Posts
· Registered
Discussion Starter · #21 ·
It seems like they have on the web page. Once you order them, give your credit card number. They will charge you immediately and silent for a while. Then they will come back and say "Sorry we don't have them in stock.". After a few days, the money is back to your credit card. If you use the same currency, nothing will happen. But if you are abroad like me, you will get charged for currency exchange quite a lot and nothing get back to you, just "sorry we don't have" Why list it in the first place?
· Lovbyts
Well that sucks than. Id better check my stash and see if I have a spare new one laying around still.
· Registered
Discussion Starter · #23 ·
I found the solution. Billets from Rvengeperformance are really good but I cannot afford that price. Especially this time with strong dollar the price in my currency becomes skyrocketing.
I ordered 93-99 oil pump from Melling and put out the billet inside to use with the old housing. They fit nicely. All the measurements are in acceptable range.
· Registered
1992 Stealth R/T Turbo
I ordered 93-99 oil pump from Melling and put out the billet inside to use with the old housing. They fit nicely. All the measurements are in acceptable range. View attachment 306824
So essentially you rebuilt your 2-bolt oil pump with the internals of a 4bolt oil pump and measured proper clearances. Nice 👌
· Registered
I have one that I removed with about 700 miles from my rebuilt 91 VR4 engine. OEM and I bought it from Mitsu Dealer around 2012ish. What is the going price for used ones these days in the USA?
If the price to sell was not worth it, My plan was to swap the gears and spring into modified 6G75 housing for my MIVEC build.
View attachment 306232 View attachment 306233
how much you selling it
· Registered
i think i have to do this as well... you positive it worked?
· Registered
It is not as simple as that. Our oil pump housing will wear out before the stock gears do. Because stock gear is steel vs cast aluminum housing. So the proper way is to measure your housing for make sure it is still good before you put in any new gear billet or stock. If you are looking for good oem or none oem used first gen pump. I have them for sale and cleaned and spec all measured ready for install.
21 - 28 of 28 Posts
