1 - 3 of 3 Posts
Just got back from my trip to KY from FL. On the way back to florida I noticed that the oil gauge is low so I went brought some motor oil and pure it in. After a while, oil is still running low... seems like it's dripping oil... I can hear dripping on the exhaust everytime I shut the engine off after a couple miles run. Also see smoke coming out of exhaust pipe... Engine stalls when I start... so got to rev it high and power brake in order to take off without killing the engine.
I've used about 70+ bottles to motor oil to get me 400+ miles home.. I really have no other choice. Is this a bad piston ring? Blown head gasket? Crack Head? Whatever that can happen? I'm not really good at talking mechanic.. so any idea what's going on?
Thank you.
Boost Leak Veteran
Turbo or Normally Aspirated (N/A)? Glad you were able to make it back safe!
if it was a turbo it could be leaking from the turbo. valve stem seals and oil rings are other oil related problems that seem common. i am assuming the smoke looked blueish (burning oil) and not white (water) is that correct? if you do a search you will probably get a lot more info a lot quicker than you will get from responces here. that sounds like a severe problem if it is going through that much oil though.
1 - 3 of 3 Posts
