1 - 2 of 2 Posts
for some reason oil is leaking from the cap on the engine. i see oil stain's on the black piece next to the oil cap. what does this mean?? is my oil cap bad.?? also there is some oil stains on the pipe for the dip stick.. what could be the problem?? should i just replace the cap.. and everything should be fine.?
LessThanSane
you can probably just replace the gasket on your cap. I did it w/ rubber gasket material from hardware store. No more leaking :)
1 - 2 of 2 Posts
