1 - 14 of 14 Posts
Wondering how efficient our OEM oil cooler is compared to aftermarket ones. What brand/style is most beneficial to a fully built motor. Suggestions and expieriences will be appreciated thanks.
Lovbyts
My OEM one has 250,000 miles on it and no problems so far except for a leaky hose I had to replace.
SDSU Alumnus
I mean... 30-year-old design compared to newer stacked-plate styles 🤷‍♂️
Drop in the bucket with a new engine... should have been done from the beginning unless you asking for later.
-sent from my Galaxy Note 9
  • Like
Reactions: rez604
1994 Mitsubishi 3000gt VR-4
I'd stay away from CX racing OC's. I am thinking that is "partially" to blame for my spun bearing. Setrab is the way to go or OEM with updated lines.
Just my $0.02.
Discussion Starter · #5 ·
This is for a fresh built stage 4 Pampena motor. I wouldnt put on a used oem on a fresh build. Thats why I'm gaging info/experience to understand what would be best oem or aftermarket. .
Discussion Starter · #6 ·
What mods you got? Sorry for the lack of info on my part. My original question was referring to a (freshly) fully built motor.
Discussion Starter · #7 ·
Just my $0.02.
Thanks for the input. Was going to pull the trigger on that cxracing setup a long while back. But lack of good feedback made me hold off.
SDSU Alumnus
At this point, it is all subjective without info or data... hell, Chris from Ninja Performance uses an OEM cooler...
Discussion Starter · #9 ·
Thanks for your input. It was not really a matter of having someone pin pointing exact what i need. It was more a matter what people are using that works really well with there set up. Hence "thoughts and suggestions on a built motor using oem oil cooler vs aftermarket". My goal is shooting for 700a whp. I have all the supporting mods. You name it. I got it. My point in this whole thread is to gather some info from others on brands or experiences. If you dont have that kinda info 😎cool.. if you do then im all eyes. Im no expert mechanic nor do I have oil cooling down to a science. (Hot oil moves through tubes/coils the fins/plates attached aid in the process of cooling depending on location of supplied air.) Thats pretty simple. Im not here to stir a debate nor get actual non productive info. Just really want to understand best brands/set up. (Kinda like the one posted in your recent instagram post with the Setrab) hell pointing out that post alone would have helped more than your last 2 responses in this thread.. its like you dont like me or something.
Lovbyts
In my signature.
Intake: WisCo 8.5-1 pistons with enlarged valve clearance, DR-13G turbos, FIDENZA LIGHTENED FLYWHEEL, Chrome Y-Pipe, K&N Filter Charger, HKS SSBOV, TurboXs boost controller, Krankvents & 3SX solid pre turbo pipes. Ignition: Taylor 8.5mm spark plug wires, NGK Iridium BKR7E (1 heat ranges colder than stock) gaped at .032
Fuel: S-AFC, PTE 550cc injectors, Denso/Supra 310lph fuel pump, Fuel pump Hotwire kit, relay bypass, Summit Fuel Pressure Regulator, Filter, EK2MFG braided dual feed fuel line kit
Exhaust: EK2MFG EGR Blockoff Plates, DN downpipe, Main cat eliminator flex section, Gutted Pre Cats, Custom Cat back, mufflers and tips
Other: Front & Rear Strut bars, Stillen Cross Drilled Rotors, Custom built, Rear adjustable Camber arms, Pillar mounted Boost gauge, EK2MFG Bling Bling. Dyno 400 WHP
If I had the time, money and doing my engine again I might change it and if it looks better why not. I was just commenting because I have not had any issue with overheating.
  • Like
Reactions: SWENDAB
Discussion Starter · #13 ·
In my signature.
Thats awesome how well the oem is doing with your setup. Thanks a bunch for your input. And sorry I failed to check your sig before asking for mod list.
Lovbyts
No worries. I know most mod list are shrunk so its hard to notice.
Best of luck whatever route you decide to go.
1 - 14 of 14 Posts
