1 - 3 of 3 Posts
SoCal3S Member
Hi there there everyone
Well I just got this 93 Dodge Stealth with a off and on check engine light.
I took a video of the light bulb codes it should be displaying.
Light bulb code reading video
I read code 21 and 41 Is this correct?
Thanks to all in advance.
Hey,
Yup you read the right codes.
I also have a 93 Stealth & i found that code 21 is an Airflow sensor error code, make sure your MAF is connected properly and is working. Had this code come up and a simple disassembly and cleaning of the MAF and replacing a dirty air filter cleared the code for me.
Code 41 is related to your injectors, perhaps they need replacing depending on your millage, but personally I found you’ll get this code coupled with code 21 if theres a problem with the detection of proper airflow into your engine. Had this happen to me a while ago too so i cleanned the throttle body replaced the gasket and changed the spark plugs & the code 41 went away.
Here’s a link with an info chart (at the bottom) to diagnose your error codes:
SoCal3S Member
Hey,
Thanks much appreciated
1 - 3 of 3 Posts
