61 - 80 of 80 Posts
Do you have 8pcs of the stack washers that go on the lower intake?
Looking for first gen pearl white passenger side skirt.
Drivers fender
Climate control module (preferably working but if not I would buy cheap to have it rebuilt)
Shipped to 55082
Do you have a '93 VR4 ECU available? (mine seems rough and mayyy be causing my issues so it'd be great to test another stock ECU before jumping on a Chrome ECU if it turns out it wasn't even my problem...)
Looking for a driver side front control arm and the right support member that runs under the trans.
Future TT convert :D
Do you have a passenger side fender, turn signal assembly, and LCA for a 2g NA? I'll also need the clamp for the big triangle bushing on the LCA. I ordered one but they canceled the ordered and informed me it was discontinued.
Bump for my specific ask. Don’t know if it is preferred to post or send a PM.
1991 Dodge Stealth Base SOHC ATX
Looking for an IAC and the harness connector, passenger side dash vent, and if you have an early 1st gen sohc I would like the TCU.
61 - 80 of 80 Posts
