The problem I see here is that when crank gear and sprockets are on they’re correct mark, the belt marks can’t be anywhere near corresponding teeth. Because corresponding teeth on all gears are not touching belt at all.Yes thank you I am aware of that. I just noticed it looks like the gates belt does have some lines on it to match up with the cam and crank sprockets and timing marks to ease the install.
Interesting, never paid any attention to different marks on back of sprockets. What indication would be used at crank gear if that was possibly?......If those lines are intended for the second marks, the ones on the back of the sprockets that align with the marks on the valve cover, well, I suppose it's possible....
Never mind Steve, after some thought I suspect there would be no line at crank sprocket and normal alignment to mark on oil pump would still be used there. Just seems it would be harder to get belt in correct orientation than to just use normal procedure.Interesting, never paid any attention to different marks on back of sprockets. What indication would be used at crank gear if that was possibly?
