Hi, as the pics show, I detached the fuel pump connector but I only can put it back that far, is this the normal depth? or something going wrong?
It will not disconnect except I pull it, but when I pull it again, I don't need to press the plastic clip then it will be disconnected after a couple of wiggles, so I used 3 zip ties to hold them together, will that be a problem? Thank you so much!
