1 - 5 of 5 Posts
Hey guys!
New “poster” lol, but I have to do the lovely rod bearings, the engine will be in the car,
But I need some help with what bearings are the “best” fit
1994 SL
Thanks!
Flasher
The best fit will be determined by how much your crankshaft is machined by the machine shop if your bearing spun. Or if you just checked clearances and it was beyond tolerance, by your measurements.
I should ask, why are you replacing rod bearings?
Discussion Starter · #3 · (Edited)
Slight “knock” really can’t decide wether it’s a few dead lifters maybe, but it idles fine, starts right up no issue, just a very obnoxious typewriter(literally loud asf) but it’s a steady tick, and it’ll get faster as gas is pressed, but sounds exactly like a typewriterThe video
BC3S
'95 RT/TT
typewriter noise on top end is lifter tick
hammer on anvil on the bottom end will be worn bearing
hard to miss with a stethoscope / screwdriver to your ear
Flasher
This. Lifter tick is much more common as well.
  • Like
Reactions: David Guye
1 - 5 of 5 Posts
