1 - 3 of 3 Posts
To make a long story short I have a wire under my power seat that is shorting to ground blowing a 30 amp fuse under the hood. While I was finding the culprit, I checked the wire harness that plugs into my driver's side door and the damned latch to the harness broke off. I called the salvage yard in California and they said I have to buy the complete wire harness for the car at $150. I then called a Mitsu dealer and they said that the connector/harness is not available. I was wondering if anyone knew of a another place or person with a wrecked 3S (RIP) that might be able to help me?
Thanks
Jeremy
94 RT/TT
#327
BFA
I wrecked my 93 R/T and it just got bought from the salvage yard the monday after christmas. I have to find out who bought it and go get the antenna motor and some other little things, and I could also see about getting the wire harness off if you give me some more info on what it is.
Jason
[email protected]
Don't know if you might be able to use a plastic wire tie to hold the connector together. Once pulled tight it won't seperate.
1 - 3 of 3 Posts
