1 - 4 of 4 Posts
I currently have a 1993 Base Model N/A and it’s leaking oil but I’m not exactly sure to as what part this is or the part number. Im pretty sure it’s the front Axle Seal but im not 100% on it, it would be great if someone could offer advice. Also should this part be slowing leaking all the time, or is does it leak only when the car is on and moving or wheels are being turned? Should I be worried, or could I drive on this to take it somewhere, I’d prefer to do it myself if it’s not that hard of a job cause I’m still new to working on vehicles
Yes that is an axle seal and it shouldn't leak at any time. You can drive it as long as there's enough fluid in the transmission.
Discussion Starter · #4 ·
Do I need to disconnect and pull everything connecting or can I just loosen it and shimmy it out enough to get the seal on? Also anyone know the part # for the 1993 Base Model 3000gt Front Axle Seal
1 - 4 of 4 Posts
