Need help with 60k from someone with a manual.......
96 Views 10 Replies 5 Participants Last post by  TFXP-Zeke01
I left my manual at work and cannot get it until Monday. I need to know what *special* order the engine support brackets bolts need to come off.
Thanks,
Aaron
1 - 11 of 11 Posts
special order? I just took them off.. :)
Just make sure you have the engine supported while you do it so it's easier..
Not the motor mount bolts. I am talking about the bracket that the motor mount bolts onto on the engine.
Thanks,
Aaron
here's what you're looking for:
<img src="http://www.3si.org/vbb/attachment.php?s=&postid=406702">
See less See more
ahh.. those.. ;) I thought you meant the 3 up on top.. my bad
good thing that some of us know what we're talking about (DUH Leland :p)
yeah, why don't you disconnect the waste gates so you can run 6psi while you at it :p (DUH Kevin)
hans, you will die now :D
remember that i am just starting out with this TT thing :p
where can you get an "over all" manual for 3si's? Would it be downloadable?
1 - 11 of 11 Posts
