Below I had listed 3 pictures and I need help removing both the parts pictured. The bolted strap at the top of the oil pan and also the oil pick up tube. I have taken off the bolts that would remove the part I am referring to but I am also wanting to know how to safely remove the gear seeing as that is the only thing keeping it on. Hopefully my questions are thorough enough to know what im talking about but this is the first engine Ive ever been inside so I am unfamiliar with most parts and pieces. Thank you in advance to those who comment, I will be using this info tomorrow to hopefully remove the listed parts.
