1 - 3 of 3 Posts
I know this due to my radiator fans not kicking in. They work when I turn my A/C on, but not to cool the engine coolant. What controls the fans turning on for temp cooling? Does the temp sensor control it?
Discussion Starter #2
need help here
come'on.... Okay, I can change the thermostat, but why would my car cool down when I'm driving if the thermostat wasn't working. My car was overheating when my fan fuse was blown, but once it was replaced the car didn't overheat. Now the fans don't turn on during normal driving unless I turn on the A/C.
there are 2 temperature sentors for the fans. They are located on the bottom pass. side of the radiator. It could be many things. You should buy a test light and start checking things. Start with fuses, then sire harness connectors, then fans and temp. sensors. I will look for a wiring diagram of the system in the manual.
Paul
92RT/TT
1 - 3 of 3 Posts
