1 - 2 of 2 Posts
I bought an 98 sl with infinity, the antenna was unhooked because the auto motor was bad. The radio only worked on AM stations, I figured this was because the antenna was not hooked up. I replaced the antenna and still had the same issue. I then read thousand of forum post on how it was possibly the fm part in the factory radio that was bad. So I bought a nice double din radio. Everything I read said just unhook the factory amp and wire the new radio in like normal. Now I have no speaker output at all. How do I wire in the factory amp or remove it.
Thanks for any help!
Robert
Senior **i.e. OLD** Member
Can you post up a wiring diagram from the new double din unit?
Or at least post brand and model?
I think I can help you but I need more info about the new unit...
Bob.
1 - 2 of 2 Posts
