1 - 3 of 3 Posts
Hi All
I have a 94 dodge stealth RT non turbo. It was sitting for a while. It always started every couple of months. I had the fuel pump replaced. Now it does not start. I’m thinking it was wired wrong or maybe the ECU. I am not a mechanic lol. I am looking for someone in the Houston area who can come take a look for me. I am in Humble
Lovbyts
If it worked before and you had a new fuel pump put in then its wired wrong as you said or the new pump is bad. Dont jump to the ECU so quick. 99% of the time it has to do with the last change you made.
Banned
It simple turn the ignition key to on and place your ear close to the fuel filler or use a stethoscope and place the end on the fuel tank, if you hear the pump whining then you have other issues
1 - 3 of 3 Posts
