1 - 3 of 3 Posts
1991 Dodge Stealth R/T N/A
Going to have to replace my fuel line after my idiot self rounded out the nut that connects the fuel line to the C-Shaped hard line to fuel filter when I put on a new fuel filter.
Anyways, should I go with a OEM line or would the stainless 3SX Line be the best option?
This would be for a 1991 Stealth R/T N/A DOHC
(It only slightly leaks fuel from the connection from the fuel line to c-shaped hardline so would there be something to put over it in the meantime to make it somewhat safe to drive or should I just leave it alone and keep it parked?)
Hi CoreyKre. I'm not able to tell you to choose one option over the other (OEM v. 3SX line). I just wanted to let you know I just replaced the fuel line in my 1991 R/T N/A with the stainless line from 3SX (my original line was rusting through at the tank). Project went smoothly and car is running great.
Discussion Starter · #3 ·
Thanks MulligansPal, I'll probably go with the stainless option. Just wanted to see if anyone has done it on the N/A and how it turned out.
1 - 3 of 3 Posts
