I'm not exactly sure where my problem lies because it's somewhere in my electrical system and troubleshooting is a bitch. Anyway, occassionally my battery will cut off if my car's been sitting for awhile, especially under cold or damp conditions. And sometimes when the battery is on when I go into the car, as soon as I turn the key you hear a *click* and the battery cuts off. If I'm hearing a click I would assume starter, but I don't see why it would keep cutting off juice from my battery. Every time it does that I have to pop the hood and disconnect and reconnect my negative terminal and eventually it will finally turn over and start. Another thing which may or may not be related, my fuse for my brake light has blown 5 times in the past month.
All this happened after an incident in which my positive terminal of my old battery connected with the hood and stalled the car. I had smoke come out of the engine and at the time everything appeared ok, but a week later I started getting the weird battery problems. I replaced the battery, thinking that maybe just one of the cells was dead, but it's still doing it on the new battery too.
