1 - 6 of 6 Posts
Another one of my many problems I need everyones help on. I have a 95 Base 3000gt and I was out cruise Sunday night when I down shited 3rd to second... Suprisingly the Clutch Didn't engage.. I had to Force it in gear and pull over to the side of the road... When the car is off I can put it into gear... When I start the car It won't go in gear... Another Funny thing is was when I pushed the clutch to the floor it stayed and I felt a funny vibration. SO I thought it was the master cylinder!!!! So i had the car towed to my house and I put a new master cylinder in it ... I bled it well and checked for pressure... Bingo I thought Id fixed it WRONG... When I started the car It did the same thing... In NEUTRAL with me putting my foot on the clutch to the floor felt the same vibration type ... And when I tried to stick it in gear I heard grinding ... So it Still wont engage... So i Checked the slave Cylinder and Nothing There were no leacks.. I just had a clutch put in 5 months back!!! Could it be my Cutch or Flywheel!!!!!!!!!! Could it be my Syncro?? What WRONG here Guys??????? I need Someone with serious knowledge to help mE!! If i take it to the dealership they'll rape me if i don't know whats wrong!!! HELP HELP HELP ASAP before TOm.
confused: Brian
Discussion Starter #2
HHHHHHHHHEEEELLLPPPP
Maybe I shouldn't of gone as far as calling it a POS, I saw what happened to that other guy.... LMAo..... But i do need immediate help
Lost Soul
Maybe throwout bearing? Pressure plate?
-Jeff
Currently Boost-less
Could be wrong, but it kinda sounds like your pressure plate collapsed.
Good luck, whatever you find out.
should take it to the shop and have them look at it. doesn't sound like something cheap though
check clutch fluid, doubt that's it, but it's possible
1 - 6 of 6 Posts
