Hey,
Back in July I began to experience electrical issues with my car. The first one I noticed was the window regulator stopped working on my passenger door. (I just replaced it a few months ago so I was pretty pissed). I plugged in the old one just to see if it was the regulator or something in the wiring wrong and it worked fine, leading me to believe my regulator was fried. Next was my dome lights. They have completely stopped working. I have found some replacement bulbs but just haven’t pulled the trigger on those yet. At this point, my alternator was charging poorly (which im unsure whether its related or not), so i replaced it. After this, my aftermarket radio went out. I’ve had it for two years and have had no issues with it. I tested my wiring to make sure it was getting power and it was, so I was led to believe my radio was fried too. Next to go was my car alarm and my key alarm (the one that goes off if you open the door with the key in the car). At this point things are getting pricey so I researched a ton and replaced my ETACS which seemed at the time to be a cause of these issues. After replacement, i still have issues. I ordered a new radio as mine was under warranty, checked all fuses, yes including 13 and 19, and went to wire my new radio up. I wire it up, nice as easy, and it still wont turn on. No power. Nothing. Same issue as before. What the hell is going on with my car??? HELP!!!
