1 - 2 of 2 Posts
91 VR4 wish scissors BBK wheels and tint
Hello,
you may remember that I found a new Mishimoto radiator at the junkyard recently.
Fantastic!......
but it seems to be an inch or so taller than stock?
am I crazy or is that right?
If I am right whats the proper installation method? Its already in the car but no way will the stock upper tabs reach the radiator support.
and is this the same as the 3SX big single core? outside of the paint it looks 100% match and I see they have a cover/mount thing.
Really old gear head
I have the Mishimoto single pass radiator that 3sx sells. I had to use the the 3sx radiator support tabs. I also had to cut off the bottom radiator support pins because they did not line up with car radiator bracket holes. I think I may have modified the bottom radiator supports to lower them. It has been over ten years since I did this so my recollection is a little fuzzy. The radiator is stable without the bottom pins. I have an extra set of new, unused 3sx radiator support tabs if you are interested. 3sx is currently out of supply and they charge $36 plus shipping. I would sell them for $25 plus shipping in a USPS flat rate box.
1 - 2 of 2 Posts
