1991 Dodge Stealth rt/tt. MFI Relay part # is e8t07871 (0913).
This relay has 9 pins. I have saw reference on the forum to both 8 and 10 pin mfi relays, but none to a 9 pin.
4l l8
3l l7
2l l6
1l l5
l(mystery pin)
Above is the pin arrangement looking at the bottom of the relay.
I have a troubleshooting sheet for the relay, but it only numbers pins 1-8 and doesn't show pin 9. Should the test sequence work for my relay? Does anyone have the correct test sequence that they could either email or post? The sheet I have is probably for an eclipse or talon and looks identical otherwise. Glad to post it if anyone needs it. Thanks,
4l l8
3l l7
2l l6
1l l5
l(mystery pin)
