I’m definitely planning on doing everything correctly and making sure everything is being supported properly. Just was wondering how much I’d be able throw at it before I need to rebuild the bottom end. Looking at maybe getting the Brian crower stroker kit and just pulling the engine and doing a full rebuildYou can make over 600whp on a stock bottom end 93-99 motor but it definitely isn't for everyone or the average results. You really need to have a solid tune in that respect, constantly monitor for knock, and be aware of any little changes in performance of the motor, sounds, oil pressure, etc. That said you can get a nice 400-450whp on pump gas and bigger TD04s with a stock bottom end. Throw on heads and cams and that'll net another 100whp. Run pump + meth or E-85 and you can run over 500whp. I wouldn't honestly push it much further than that in order to give you a safety margin of error. The piston ringlands will break first with detonation so it really is all in the tune. A flashed ecu with Chrome works just fine.
Since you'll have a 6-speed you won't need any 300m components. That's only on the 5-speeds that it's necessary. Plenty of 700-1200whp are running stock output shafts on the 6 but just about everything else is upgraded including billet shift forks, billet endcase, billet midbrace, billet bell housing brace, and so far no solution for upgraded transfercase gears that strip. I've run 5-600whp on an all stock 6-speed just fine with no issues and so have plenty of others. Just don't go crazy with 7k clutch dumps or lauches on slicks at the track.
It's really going to depend on the tune. Knock will kill it in a heartbeat whether it's 300 or 500whp. If you get someone to get a solid safe tune on it that has built many of these cars before at upgraded power levels, then you'll be plenty fine with 450-500whp pretty safely for awhile. You could maybe get by with higher power on a TD05 setup vs TD04 since it'll hit full boost a 4k rpms and have much less mid range torque and cylinder pressures but realistically it sounds like you aren't too familiar with these cars. I would say go for a 15G 400whp setup or 19/20T 450whp setup on pump gas and be done with it. The BC stroker kit is way overkill unless you plan to push more than 750wtq where the stock forged crank can start bending. Save your money and go with a Stage 3 Pampena shortblock. It'll handle anything you can throw at it by the sounds of what you're doing. Pampena Motorsports Stage 3 EngineI’m definitely planning on doing everything correctly and making sure everything is being supported properly. Just was wondering how much I’d be able throw at it before I need to rebuild the bottom end. Looking at maybe getting the Brian crower stroker kit and just pulling the engine and doing a full rebuild
I'm looking at a safe pump (only 91 in California) build on my 1991 VR4You can make over 600whp on a stock bottom end 93-99 motor but it definitely isn't for everyone or the average results. You really need to have a solid tune in that respect, constantly monitor for knock, and be aware of any little changes in performance of the motor, sounds, oil pressure, etc. That said you can get a nice 400-450whp on pump gas and bigger TD04s with a stock bottom end. Throw on heads and cams and that'll net another 100whp. Run pump + meth or E-85 and you can run over 500whp. I wouldn't honestly push it much further than that in order to give you a safety margin of error. The piston ringlands will break first with detonation so it really is all in the tune. A flashed ecu with Chrome works just fine.
The output shafts can break and strip at stock power levels and also the transfercases have cracked/broken as well. It's a crap shoot rolling the dice because you don't know how fatigued the cast aluminum is over 30 years. Preloading the drivetrain and not really launching it will go a long ways. A 300m OS and transfercase brace would be really nice to have but still won't completely save your transfercase. It'll just make it a matter of time before it breaks. The only solution is billet front and mid cases. I run LIPP 304SS front and mid housings on my 5-speed with a 300M OS but they don't make those cases anymore. You'll have to go through Rvenge for what you need: https://www.rvengeperformance.com/product/3000gt-dodge-stealth-billet-transfer-case-5-speed/.I'm looking at a safe pump (only 91 in California) build on my 1991 VR4
And known issues with the 5spd?
Sent from my LM-G850 using Tapatalk
Will all the 6g72 parts go into this block?It's really going to depend on the tune. Knock will kill it in a heartbeat whether it's 300 or 500whp. If you get someone to get a solid safe tune on it that has built many of these cars before at upgraded power levels, then you'll be plenty fine with 450-500whp pretty safely for awhile. You could maybe get by with higher power on a TD05 setup vs TD04 since it'll hit full boost a 4k rpms and have much less mid range torque and cylinder pressures but realistically it sounds like you aren't too familiar with these cars. I would say go for a 15G 400whp setup or 19/20T 450whp setup on pump gas and be done with it. The BC stroker kit is way overkill unless you plan to push more than 750wtq where the stock forged crank can start bending. Save your money and go with a Stage 3 Pampena shortblock. It'll handle anything you can throw at it by the sounds of what you're doing. Pampena Motorsports Stage 3 Engine
Yes it's a 3.0L 6G72 block. You have to send in a block and crankshaft as a core.Will all the 6g72 parts go into this block?
As far as the 300m was a aftermarket upgrade to make the shaft stronger. The billet xfer case looks nicer and is stronger. Most people run the stock transfer case but use a transfer case brace, along with a transmission bellhousing brace.@TurboSinceBirth
@ThatOneVr4
While I am experienced with mechanical stuff, I'm more domestic like Ford and JDM like kawasaki and Suzuki....
Is there a wiki that explains 304SS, 300m and what came with 18 or 24 spline and what that entails?
I keep hearing about an output shaft and like the DR800 turbos... Not a clue what some of it means.
I'm still trying to wrap my head around the TD04 stuff, like 9b 13b thats fine... But HL and some of the other things are out of my experience.
It's also a strange car.... Something like my 70 firebird with a holly double pumper I have no problem... That's all mechanical with springs and cables.... A rack of carbs on my bikes is easy as well.... I'm actually an IT guy and have been able to work on my 14 F150 ecoboost.... But the VR4 is fuel injected and vaccum operated... But unlike my my truck it lacks the computer or sensors for someone not experienced in this platform
I keep reading 318 and 3si... But I still get a lot of stuff that has me scratching my head. Like why would I need a billet Xfer case? I've never heard of that cracking in anything... And if I recall we have getrags?
Anyway.... I need a wiki or to pick the brain of someone experienced
The output shaft is the 18/25 spline thing people keep talking about, the 300m is a hardened is like the hardened beefy big brother of the stock output shaft.what came with 18 or 24 spline and what that entails
9b is the stock turbo, 13g are slightly better flowing turbos and actually came stock on the EU vr4s. As for designations like "H" and "HL" those are referring to the compressor housing size, with HL being the biggest. Common HL turbos are 20ts or similar. TD04HL turbos usually have slight fitment problems on our cars due to the radiator fan and motor mounts.I'm still trying to wrap my head around the TD04 stuff, like 9b 13b thats fine... But HL and some of the other things are out of my experience.
I'm not even sure what this statement means? Are you referring to the fact that the fuel pressure regulator uses vacuum? Because it isn't that uncommon.But the VR4 is fuel injected and vaccum operated... But unlike my my truck it lacks the computer or sensors for someone not experienced in this platform
