This is in deed touch frame only but it still works for what I need it to do .... it does record on set amount in options while parked or you can set it up for protections (bump) recording while the car is parked unattended....
Front camera looks good the rear camera as well I do get a 1 blurry line that floats thru the screen from top to bottom I'll have to check some more into it..... while the car is being driven and not on a battery tender sitting in garage
With the mirror screen off it will automatically turn the rear camera on (in reverse) and give you proximity parking lines if you hook the back up wire up to your reverse light itself...... either one on POS.. side ....will be fine
Up front the mirror itself has
Memory wire for parked car recordings
power and ground this wire harness hooks up to the mirror then T's off .... one harness for power the other for rear camera
Really simple to hook up
The front camera can be tilted up or down in the settings along with the rear camera as well... the lens its self moves in increments with each touch..... no left or right without manually adjusting either one
I did notice while I put date and time in everything was good but I can't change the week day .... again i have to investigate why
But here are a couple pics
(Rear camera not installed on bumper its hanging down I'll finish in the morning when I can pull car out and center it)
