So it's been a very long time since I have been talking about my build but no news or anything out of it. The reason is because I didn't want to go with off the shelf parts and had to do many customer parts that took a long time to get done. It's still not 100% done but it's mostly there besides piping and putting the engine together. I have been thinking how I can get rid of turbo lag on big turbos cars like ours specially with 5 speed. I have been thinking to add a supercharger with a clutch that would only works at lower rpms and I bought a 10 inch pulley that had a difficult time making it fit. Couldn't fit on over the damper since it would hit the frame so I had to test fit and machine it many time to make it fit on the inside to replace the ps pulley. The supercharger was going to be where ac compressor used to be, but that plan will be scrap and will go with a quick spool valve that I saw on Bugatti Chiron. I also was tired of crappy intake manifold so I did many different mods to have a short ram intake while making injectors fit. Brian's idea on fuel rail is the most convenient setup but I wanted to have the injectors to spray in to the intake ports. A Cosworth 370z fuel rail fixed that. I even bought 370z fuel rails and machine them to fit under the tank but I decided to scrap that too since I was not sure on their fuel flow capability. Shit ton of money was wasted. I wish I could do fabrication and machining. It would have saved me thousands of dollars. Now for a few pictures.
