Hi all, Larry here
I’m based in Dublin ireland and new to the site
I’m having a head scratcher of a problem, I completed an full engine rebuild and ever since the car refused to idle , I could get it to start randomly , but would get several pops and bangs from it fuel pump would shut off and it would die . So I’ve changed ptu, coils, leads , all injectors are 360 type , even had my stock ecu fully tested and no fault was found . So one day I decided to try my spare non turbo ecu in the car( I’d tried everything else at this point so I thought what the hell). And boom fired right up and ticks over fine , I obviously can’t Rev the car as it’ the wrong Ecu , fuel ratio etc however it proved at least the engine rebuild was done correctly .
Has anyone any suggestions as to why the car will fire up and tick over on a non turbo ecu but misfires on a fully tested TT ecu …. I’m 18months on and off trying to fix this so truly about to loose my mind
regards Larry
regards Larry
