1 - 5 of 5 Posts
What is the difference between the two different blocks?
Thanks
a shortblock is the lower assembly of the motor.
longblock includes heads.
theres no difference in the actual block.
TheJackal said:
so is a longblock, the whole engine or just the heads?
Block heads and internals... Nothing that bolts onto the block or heads... But you get the valve, springs, oil pump, the whole nine.... Not sure if you get timing belt and such with it or not...
1 - 5 of 5 Posts
