1 - 4 of 4 Posts
Any of you guys have this problem? If so, could you please enlighten me on how to correct the problem? Thanks guys.....
-Jason
graphite lube ?
Do you mean it's sticking together or it gets hung on itself ?
If it's not lubed properly I'd recommend a graphite lube (hardware stores carry it). If it's sticking, you might try adjust the contents of the compartment and see if that helps. Pressure from contents might put stress on the latch.
Glove box latch is a chronic thing. I had to replace them in both my Stealths. I think the part was over $100.
I had to have mine replaced. Now the second one is messing up too. Worst thing about it, the yahoos at the dealership failed to replace the new cam in the lock with the old one. Now I have a separate key for the glove box!
Next time I'm fixing it myself. I'd much rather do the shitty work myself...that way I nobody to blame but myself!
1 - 4 of 4 Posts
