Hi All,
I would like to give a quick feedback about my kinugawa 20t turbos. Kinugawa Upgrade CHRA Kit MHI 6G72T 3000GT 6+6 TD04HL-20T Anti Surge housing with 9 Blades turbine. After a long time waiting, I finally got the time to finish my build. The car is 1999 VR4 with the following mods:
• Oem internals 6g72
• Adjustable timing gears (+1/-3)
• kinugawa 20t turbos
• Aem EMS S2 /Acc
• Walbro 450 E85 fuel pump hot wired
• PTE 1000CC (will be replaced soon for ID 1050X, E85 friendly)
• Oem ignition
• Dual core FMIC
• K&N air filter
• Aftermarket oil cooler
• CSE center diff
• Quaife front diff
• Rear hybrid diff(H4) oem
• XTD stage 4 6 puck (holding good, but I hate button clutch)
• BC coilovers
• Borla turbo back exhaust
• E85
• lots of other smaller mods
I almost got the tune dialled in. In the process of tunning I had a drive the car at different loads and speeds. I can say that there is almost zero turbo lag if you are in the right gear. If you are in 4th gear at low speed (1800 RPM), then you slam the throttle, it might take a second or so to get into boost. I can see positive pressure as low as 1800 RPM. Quite impressive. Currently, the boost is limited to 15 PSI till I get to the dyno. I took the car to a deserted road and did a second gear run (multiple) and logged the runs. I loaded the last log into Virtual Dyno and the result:
[email protected] and 424lbft [email protected]@14.6PSI
The dip around 5300RPM is duo to timing being set to 13 degree. @5500 RPM is was set to 19. This is fixed now.Also, I have set AEM to cut ignition at 15 PSI, which is why my run was till 5600 RPM. I have taking the car to red lines multiple times with lower boost (with 9b I was straggling to get to red line lol). I'm planning to run 19 PSI or till I get 500 AWHP, my target. I will be taking the car to the dyno to be tuned for WOT shortly (after I change the injectors). The car idles and drives as stock. It took me a while to get the AEM tuned correctly.
I will be updating this thread with my progress so keep watching.
• Aem EMS S2 /Acc
• Oem ignition
• Dual core FMIC
• K&N air filter
• CSE center diff
• Quaife front diff
• BC coilovers
• E85
