1 - 4 of 4 Posts
B
Guest
I just put 4 brand new snow tires on my Stealth R/T (215/60/R16) and now the car pulls quite a bit to the left; especially at high speeds. The car was fine on my originals. Does anyone have any ideas why it's doing this? Alignment? Tie rods?...
Thanks!
Bomber.
'94 Stealth R/T
J
Guest
Discussion Starter #2
Could be 'radial pull' which is where one of the tires' belts are misaligned. The supposed fix for this is only a new tire.
If the problem just ocurred after changing tires I would certainly suspect the tires as a first step- I would switch front and back to see what happens.
B
Guest
Discussion Starter #4
Thanks John.
How do you know if this is the problem? Is there an easy test that can be performed?
Bomber.
'94 Stealth R/T
1 - 4 of 4 Posts
